ExtremeWireless Hardware Firmware Support Matrix
Use the following information to easily determine the currently supported firmware version and the minimum firmware version for each ExtremeWireless Access Point.
AP SeriesProduct Number Product DescriptionProduct Long DescriptionMin FW VersionSupported FW VersionsXCloud Support
AP3912 - Wall-plate , Dual band, Dual Radio 802.11ac/abgn, 2x2:2 MIMO Indoor Wave 2 access point that offers a range of connectivity options, including three policy controllable wired LAN ports (2.4/5G) and a wired pass-through port.31025WS-AP3912i-FCCIncludes a four internal antenna array. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia).v10.21.01v10.21Yes
AP3935 - Dual band, Dual Radio 802.11ac/abgn, 4x4:4 MIMO Indoor Wave 2 access points.31012WS-AP3935i-FCCIncludes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia).v10.01.01v10.11 or v10.21Yes
31013WS-AP3935i-ROWIncludes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia).v10.01.01v10.11 or v10.21Yes
31014WS-AP3935e-FCCIncludes eight, external , N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia).v10.01.01v10.11 or v10.21No
31015WS-AP3935e-ROWIncludes eight, external , N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia).v10.01.01v10.11 or v10.21No
31020WS-AP3935i-ILIncludes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: IL (Available in Isreal).v10.11.02v10.11 or v10.21Yes
AP3965 - Dual band, Dual Radio 802.11ac/abgn, 4x4:4 MIMO Outdoor Wave 2 access points.31016WS-AP3965i-FCC Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia).v10.01.02v10.11 or v10.21Yes
31017WS-AP3965i-ROW Includes an eight internal antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than the U.S., Puerto Rico, and Colombia).v10.01.02v10.11 or v10.21Yes
31018WS-AP3965e-FCC Includes eight, external , N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia).v10.01.02v10.11 or v10.21No
31019WS-AP3965e-ROWIncludes eight, external , N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than the U.S., Puerto Rico, and Colombia).v10.01.02v10.11 or v10.21No
AP3805 - Dual band, Dual Radio 802.11ac/abgn, 2x2:2 MIMO Indoor Wave 1 access points. 30912WS-AP3805i-FCCIncludes four internal antenna array. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia).v10.01.04v10.11 or v10.21Yes
30913WS-AP3805i-ROWIncludes four internal antenna array. Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia).v10.01.04v10.11 or v10.21Yes
WS-AP3805i WS-AP3805iIndoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards.v9.15.01v9.21, v10.11, or v10.21No
WS-AP3805e WS-AP3805eIndoor AP with external antenna connectors. Supports the 802.11ac wireless standards.v9.21.01v9.21, v10.11, or v10.21No
Mfg rev 5K or greater.
v9.21.10v9.21, v10.11, or v10.21No
AP3801WS-AP3801iWS-AP3801iIndoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards.v9.21.01v9.21, v10.11, or v10.21No
WS-AP3801iWS-AP3801iIndoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. Mfg rev 5F or greaterv9.21.10v9.21, v10.11, or v10.21
AP3825 WS-AP3825iWS-AP3825iIndoor AP with internal antenna assemblies. Supports the 802.11ac and 802.11n wireless standards.v9.01.01v9.21, v10.11, or v10.21No
WS-AP3825eWS-AP3825eIndoor AP with external antenna connectors. Supports the 802.11ac and 802.11n wireless standards.v9.01.01v9.21, v10.11, or v10.21No
WS-AP3825iWS-AP3825i-1Indoor AP with internal antenna assemblies. Supports the 802.11ac and 802.11n wireless standards. App ID WS-3825i-1 (mfg rev 5L or greater). Units produced after May 2016.v9.21.08 or v10.01.04v9.21, v10.11, or v10.21No
WS-AP3825eWS-AP3825e-1Indoor AP with external antenna connectors. Supports the 802.11ac and 802.11n wireless standards. App ID WS-3825e-1 (mfg rev 5L or greater). Units produced after May 2016.v9.21.08 or v10.01.04v9.21, v10.11, or v10.21No
AP3865 WS-AP3865eWS-AP3865eOutdoor AP with external antenna assemblies. Supports the 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac protocols.v9.12.01v9.21, v10.11, or v10.21No
AP3705WS-AP3705iWS-AP3705iIndoor AP with internal antennas, 2x2x2 802.11abgnv8.11.05v9.21, v10.11, or v10.21.No
AP3710WS-AP3710iWS-AP3710iIndoor AP with internal antennas, 3x3x3 802.11abgnv8.21.04.24v9.21, v10.11, or v10.21No
WS-AP3710eWS-AP3710eIndoor AP with external antennas, 3x3x3 802.11abgnv8.21.04.24v9.21, v10.11, or v10.21No
AP3715WS-AP3715iWS-AP3715iIndoor AP with internal antennas, 3x3x3 802.11abgnv8.31.01v9.21, v10.11, or v10.21No
WS-AP3715eWS-AP3715eIndoor AP with external antennas, 3x3x3 802.11abgnv8.31.01v9.21, v10.11, or v10.21No
AP3765WS-AP3765iWS-AP3765iOutdoor AP with internal antennas, 3x3x3 802.11ac, 802.11abgn v8.21.01v9.21, v10.11, or v10.21No
WS-AP3765eWS-AP3765eOutdoor AP with external antennas, 3x3x3 802.11ac, 802.11abgn v8.21.01v9.21, v10.11, or v10.21No
AP3767WS-AP3767eWS-AP3767eOutdoor AP with external antennas, 3x3x3, 802.11n, 802.11a/b/gv8.21.01v9.21, v10.11, or v10.21No
AP3660WS-AP3660eWS-AP3660eOutdoor AP with 6 ports for external antennas, dual radio 802.11a/b/g/nN/Av9.21.No
AP 3640-ROW/NAM/ILWS-AP3640i/eWS-AP3640i/eIndoor APs with internal/external dualband antennas, dual radio 802.11a/b/g/nN/Av9.21.No
AP3630-ROW/NAM/ILWS-AP3630i/eWS-AP3630i/eIndoor APs with internal/external dualband antennas, dual radio 802.11a/b/g/n standaloneN/Av9.21.No
AP3620-/ ILWS-AP3620i/eWS-AP3620i/eThin APs with internal/external dual-band antennas, dual radio 802.11a/b/g/n N/Av9.21.No
AP3610/- ILWS-AP3610iWS-AP3610iIndoor AP with six internal antenna array, Dual Radio 802.11a/b/g/n, 3x3:2. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal).N/Av9.21.No
AP 3605-ILWS-AP3605iWS-AP3605iDual radio 802.11a/b/g/n thin AP with internal dual-band. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal).N/Av9.21.No
AP2660-/ILWS-AP2660i/eWS-AP2660i/eOutdoor industrial AP with internal/external antennas, dual radio 802.11a/b/g. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal).N/Av9.21.No
AP2650-/ILWS-AP2650i/eWS-AP2650i/eOutdoor industrial AP with internal/external antennas, dual radio 802.11a/b/g. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal).N/Av9.21.No
AP2640-EUWS-AP2640i/eWS-AP2640i/eDual radio 802.11a/b/g standalone APs with internal/external antennas that
can optionally be configured to operate in thin mode -EU version has a Restricted Regulatory Domain: Rest of World.
N/Av9.21.No
AP2630-EUWS-AP2630i/eWS-AP2630i/eDual radio 802.11a/b/g standalone APs with internal/external antennas that
can optionally be configured to operate in thin mode. Restricted Regulatory Domain: Rest of World.
N/Av9.21.No
AP2620-/ ILWS-AP2620i/eWS-AP2620i/eDual radio 802.11a/b/g thin APs with internal/external antennas. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal).N/Av9.21.No
AP2610- /ILWS-AP2610i/eWS-AP2610i/eDual radio 802.11a/b/g thin APs with internal/external antennas. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal).N/Av9.21.No
AP2605-/ ILWS-AP2605i/eWS-AP2605i/eDual radio 802.11a/b/g thin APs with internal/external antennas. -IL version has a Restricted Regulatory Domain: IL (Available in Isreal).N/Av9.21.No
