XENPAK, XFP and CFP2 Module Support
Print Friendly
Use the Print button above to print the contents of this section or save it to PDF. To find every instance of a device or part number, use your browser’s search feature. To find a device or part number in a particular table, use the Search box for that table.
Summit X350 Switches: XENPAK Support
XENPAK ModulePart No.Minimum ExtremeXOS Software VersionComments
ER1011212.0.3.16
LR1011112.0.3.16
SR1011012.0.3.16
ZR1011312.0.3.16
LX41011412.0.3.16
Summit X350 Switches: XFP Support
XFP ModulePart No.Minimum ExtremeXOS Software VersionComments
ER1012412.0.3.16
LR1012212.0.3.16
SR1012112.0.3.16
ZR1012512.1.2.17
Summit X450a Switches: XENPAK Support
\XENPAK ModulePart No.Minimum ExtremeXOS Software VersionComments
ER1011211.6.1.9
LR1011111.6.1.9
SR1011011.6.1.9
ZR1011311.6.1.9
LW10116E11.6.1.9
CX412.0.1.11
LX41011411.6.1.9
Summit X450a Switches: XFP Support
ER1012411.5.1.4
LR1012211.5.1.4
SR1012112.0.2.25
ZR1012512.1.2.17
Summit X450e Switches: XENPAK Support
ER1011211.5.1.4
LR1011111.5.1.4
SR1011011.5.1.4
ZR1011311.5.1.4
CX412.0.1.11
LX41011411.5.1.4
Note: XENPAKs not supplied by Extreme Networks will show up as Unsupported Optic Module in the output from show ports x:y information detail and show ports x:y configuration.
Summit X460 Switches: XFP Support
XFP Module (requires XGM3S-2xf option card)Part No.Minimum ExtremeXOS Software VersionComments
ER1012415.1.1
LR1012215.1.1
SR1012115.1.1
ZR1012515.1.1
Tunable DWDM (up to 80 channels)1020015.1.1
Summit X480 Switches: XFP Support
ER1012412.4.1
LR1012212.4.1
SR1012112.4.1
ZR1012512.4.1
Tunable DWDM (40 channels)1020012.5.1
Tunable DWDM (80 channels)1020012.6.1
ExtremeSwitching 8000 Series Switches: XFP Support
ER1012412.0.2.25
LR1012211.6.1.9
SR1012111.6.1.9
ZR1012512.1.2.17
ExtremeSwitching X8 Series Switches: CFP2 Support
CFP2 ModulePart No.Minimum ExtremeXOS Software VersionComments
SR101033115.5.1
LR41033015.5.1
E4G-Series Switches: XFP Support
ER1012415.1.1
LR1012215.1.1
SR1012115.1.1
ZR1012515.1.1
We value your feedback about Extreme Networks documentation. Use our online feedback form to post a comment or suggestion about this information.
Want to be notified when this information changes? Sign up for email updates:
To be notified whenever this page is updated, supply your email address. We’ll use your email address only for sending these notifications.
